EPC light on instrument cluster
76,000 MILES • 5 CYL • 2WD • AUTOMATIC
PHILMARVT
  • 8 POSTS
Hi folks:
We are thinking of purchasing the car listed above (2.5 sedan) for our grandson. The question I have is the EPC light was on the instrument cluster. The dealer said they replaced one spark plug and coil pak and the light went off. Does this sound like the correct fix or should I be worried something more serious is wrong?
Let me know and thanks in advance for your help.
Phil
Dec 20, 2017 at 3:35 AM
  • 55,732 POSTS
It depends on the code that was recorded. I would take a scanner with you and read the codes yourself to see if there are pending just to be safe. Here is a guide.
Cheers, Ken
Dec 22, 2017 at 8:55 AM
