EPC and two other warning lights will not go off?
143,000 MILES • 2.8L • 6 CYL • 2WD • MANUAL
ROBBWO50
A few months ago, the battery on my Jetta GLI went completely dead. I charged the battery and when I started the EPC light came on. I went to YouTube and followed the instructions to reset the computer. Disconnecting the battery cables and connecting together for an hour or so. It did not work. I then took the car to a dealer. They said they thought it was the Mass Air Flow Sensor. They wanted $600.00 for the part and installation. I replaced it for $49.00 and fifteen minutes of my time. I tried the battery cable trick again and now I have three trouble lights. the EPC, ASR/ESP and the Malefaction Indicator light. The engine runs great, plenty of pickup, it does idle a little rough.
Oct 13, 2022 at 7:44 AM
  • 110,248 POSTS
I'm not sure what a mass air flow sensor does with stability control. LOL Anyway, in most cases when you have these lights on at the same time, it is the result of a faulty wheel speed sensor.
If you have access to a live data scanner, see if all wheel speeds are the same when the vehicle is moving. If one is different or not showing a signal, replace that sensor.
If you don't have access to a live data scan tool, here is a link that explains how to test each sensor with a voltmeter or multimeter.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Let me know what you find.
Oct 13, 2022 at 1:38 PM
