Epb,ABS light is on
129,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
BIGD0326
  • 11 POSTS
First thing car wont come out of park . brake light is on, traction control light is on, ABS light is on. Low beam headlights don't come on. can someone help me please? Also have numerous DTC codes.
Feb 20, 2019 at 3:18 PM
Good morning,
Does the car run?
The ABS system has a fault code stored. When this happens, it will take the trac system off line until the ABS is repaired.
As far as the headlights, did anyone verify power to the headlights to be sure the bulbs are good?
Can you post the other codes?
Feb 20, 2019 at 9:09 PM
BIGD0326
  • 11 POSTS
9317, e518, d900, 9246, 9352, 9470, 9318, e510, e521, e523, 9689, 9875, 9567, a472, e522. As far as lights go no the power hasn't been checked i will do that. Yes, the car runs.
Feb 20, 2019 at 9:52 PM
Okay,
That is a lot of codes. Chances of all that going wrong at the same time is very small.
I would start by load testing the battery. Low voltage is a common reason for a lot of codes.
Check your charging system for 14 to 14.5 volts. Also, check for any Ac voltage while the engine is running. That will confuse the ECM and it will throw a lot of codes.
Feb 20, 2019 at 10:03 PM
BIGD0326
  • 11 POSTS
Okay, i will. Thanks. could any of that be why it wont shift from park?
Feb 20, 2019 at 10:33 PM
You are welcome.
Always glad to help.
Feb 20, 2019 at 10:35 PM
BIGD0326
  • 11 POSTS
Okay, i put a new battery didn't help other then it will start on its own now. Still have parking brake fault, ABS fault and traction control light is always on.
Feb 21, 2019 at 5:16 AM
Okay. As I stated before, the ABS will take the trac system out of service until it is repaired.
As far as the brake light, that should be the red brake light related to the ABS.
Can you check the codes now?
What about the charging system as I stated before? voltage both AC and DC?
Feb 21, 2019 at 5:21 AM
BIGD0326
  • 11 POSTS
How do i check voltage? As far as codes if checked with obd2 i get p1637, if i go through the car diagnostic nothing has changed.
Feb 21, 2019 at 5:32 AM
BIGD0326
  • 11 POSTS
And still wont shift out of park.
Feb 21, 2019 at 5:33 AM
You need a volt meter to do those checks. If you do not have one, you can get one at a parts store for cheap.
Let me check the code.
Feb 21, 2019 at 5:39 AM
BIGD0326
  • 11 POSTS
Okay, i will need to wait until later when i have some help to test alternator.
Feb 21, 2019 at 5:40 AM
Okay, check the brake light switch on the brake pedal. That is what controls the interlock for shifting. Once again, you need a voltmeter to test for voltage on both sides when the pedal is depressed.
As far as the code, it is for the wheel speed sensor. they need to be checked or monitored to see if they are sending signals.
you need an advanced scan tool to monitor these sensors.
Feb 21, 2019 at 5:49 AM
Sounds like a plan.
Feb 21, 2019 at 5:53 AM
BIGD0326
  • 11 POSTS
Tested alternator, It checked out good. no a.c. didn't get a chance to check out brake switch maybe tomorrow . thanks for all your help.
Feb 21, 2019 at 10:07 AM
You are welcome.
Feb 21, 2019 at 10:55 AM
BIGD0326
  • 11 POSTS
I checked the switch on the brake pedal. i have power to the switch and the switch is working.
Feb 22, 2019 at 11:00 AM
BIGD0326
  • 11 POSTS
I still have code p1637 comes back after i erase them.
Feb 22, 2019 at 11:02 AM
I am trying to find a wiring diagram for the ABS system so you can verify powers and grounds to the unit but I am not having much luck finding one.
I will keep looking for you.
Clearing does nothing until the issue is determined and repaired.
Feb 22, 2019 at 8:34 PM
I found this diagram. Take a look at it.
You would need to download and then you can enlarge it.
Feb 22, 2019 at 9:43 PM
