Entire row of fuses getting not getting power
125,000 MILES • 3.7L • 2WD • AUTOMATIC
MARLENE325
I changed out the starter and solenoid and both are in good condition. They have no problems. Now my car won't start at all. Battery is good and charged. Never had this problem before. Found that an entire row of fuses are not getting any power to them and they do not show signs of being burned out. I'm at a loss. What should I do?
May 21, 2022 at 6:37 AM
  • 110,244 POSTS
In most cases, power to the fuses is supplied by a larger primary fuse. If it fails, you can lose power to several other fuses.
I need to know what fuses lost power and which fuse box has been affected.
May 21, 2022 at 3:35 PM
