Entertainment center not turning on?
174,000 MILES • 6 CYL • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
Replaced battery, now the main screen for camera and bav is not powering on.
Oct 11, 2022 at 5:14 AM
BHAMDOC1973
  • 2,007 POSTS
I used the steering controls, and the radio came on, voice activation also works. Also, when i press the buttons on the main info fe ter say to change bands it works. From main screen volume works, tracking and all.
Oct 11, 2022 at 5:34 AM
BHAMDOC1973
  • 2,007 POSTS
Did a can scan and there were a ton of codes of course cause battery was bad. Deleted all and all i have left are these.
Oct 11, 2022 at 9:29 AM
  • 110,251 POSTS
Does the vehicle have navigation? Also, what does the BAV stand for? I don't recognize it.
Oct 11, 2022 at 1:06 PM
BHAMDOC1973
  • 2,007 POSTS
Has nav yes. What BAV?
Oct 11, 2022 at 1:22 PM
  • 110,251 POSTS
I just figured out what BAV is. In your first post, I think you meant NAV. LOL
As far as the code U1243, I attached the diagnostics specific to it. If you take a look below, read through what is suggested and let me know if you are comfortable performing them.
Oct 12, 2022 at 10:17 AM
BHAMDOC1973
  • 2,007 POSTS
What does AV refer to?
Oct 12, 2022 at 10:30 AM
  • 110,251 POSTS
AV stands for audio visual.
Let me know how things are going.
Oct 13, 2022 at 11:04 AM
BHAMDOC1973
  • 2,007 POSTS
Am not understanding which other harness am supposed to check as far as av. I have pulled screen out and it has a harness, what do i check as far as the av, where is it and what connects to it?
Oct 15, 2022 at 10:58 AM
BHAMDOC1973
  • 2,007 POSTS
Scanned it and got these, deleted them and second pic shows the codes that showed. Disconnected battery fir a while same results
Oct 15, 2022 at 12:26 PM
  • 110,251 POSTS
The two codes that are stored are related. They seem to be related to the multi-function switch. See attached below. I say the switch because it is present in both codes. See pic 1
The multi-function switch ties to the front display, and the A/C control unit. I attached the wiring below.
Let me know if this helps.
Oct 16, 2022 at 11:49 AM
BHAMDOC1973
  • 2,007 POSTS
You mean the multifunction switch on steering? That can cause this issue?
Oct 16, 2022 at 11:53 AM
  • 110,251 POSTS
I'm looking through the schematics again and they don't specify. If that is the only AV switch, I would have to say yes.
Oct 16, 2022 at 1:50 PM
BHAMDOC1973
  • 2,007 POSTS
if you are confused about it then so am I, lol. I am not going to know more than you. Yes, I have no idea what or how to identify what or where the AV is.
Oct 16, 2022 at 9:57 PM
  • 110,251 POSTS
The schematics are vague but extremely extensive. LOL Not having things in front of me for this issue makes it extremely difficult because I can't compare what I'm seeing with what is on the vehicle. If there is an AV switch on the steering, that must be it.
Oct 17, 2022 at 10:33 AM
