Engine will not start
51,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
GIXXERGOON
I have the car listed above as the battery and dead tried to boost it off. It will current but we're not start the and top then fly used to blink now does not work. Also, hazard lights do not work As words the windows is there any way to by pass so I do not have to take to shop? I'm a poor 30 year old, lol.
May 16, 2020 at 2:31 PM
  • 55,694 POSTS
The first thing we should do is check the fuses. here is a guide and the fuse location in the diagrams below:
This guide can help as well.
May 17, 2020 at 3:46 AM
GIXXERGOON
Yes sir, we checked all the fuses they all seem to be in right shape. I called a locksmith who deals with this sort of is you he said he could not get in with his computer something about and taught the shut down. I was wondering if you think it's possible a brain box would be blue and if there's anything I can do cheaper than taking it into the shop? I'm barely making it as it is these days. thank you for your quick reply.
May 17, 2020 at 8:51 AM
  • 55,694 POSTS
When you turn the key on and try to crank the engine over does the security light flash? if so this guide will help us:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
May 18, 2020 at 2:52 AM
GIXXERGOON
I just replaced the battery! I removed off my parts car the fuse box underneath the hood replaced every fuse still won't start.
May 20, 2020 at 3:01 AM
  • 55,694 POSTS
Thanks for the video but it sounds like the timing chain has let go. Lets pull a spark plug out and do a compression test you can get a gauge from the part store for free (they will lend you one) to confirm the failure. This guide will help:
May 20, 2020 at 3:58 AM
GIXXERGOON
I had the Nissan dealership diagnosed my car this is what they gave me! I have a buddy who told me Nissan was just trying to pump me for as much money instead of telling me the easy way to fix it resetting the ECU computer system. what do you think?
May 23, 2020 at 9:11 AM
  • 55,694 POSTS
These can be caused by a timing belt being off one tooth. Can we do the compression test to confirm or remove the timing belt cover?
May 24, 2020 at 3:34 AM
