engine bolts torque settings
2002 MAZDA DEMIO
120,000 MILES • 1.5L • 4 CYL • FWD • AUTOMATIC
FAFATECH500
i am doing an engine so i am looking for engine torques.
Dec 20, 2016 at 4:52 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
Hey Fafatech500,
We don't have this car in the states but I think I found the specs that will work , please let me know.
Install the main bearing caps.
Tighten the bolts using the sequence shown in two stages.
Stage 1: Tighten the bolts to 25 Nm (18 lb-ft).
Stage 2: Tighten the bolts an additional 60 degrees.
Install the connecting rod caps.
Install new bolts and tighten in two stages:
Stage 1: Tighten to 35 Nm (26 lb-ft).
Stage 2: Tighten an additional 90 degrees.
Install the cylinder head and tighten the bolts in three stages using the sequence shown.
Stage 1: Tighten the bolts to 20 Nm (15 lb-ft).
Stage 2: Tighten the bolts to 40 Nm (30 lb-ft).
Stage 3: Tighten the bolts an additional 90 degrees.
Best, Ken
Dec 22, 2016 at 12:48 PM
MAXIMILIAM
  • 436 POSTS
Hi ken
Thank for the torque settings , they really worked well .
Best Regards,
Fafatech500
Jan 9, 2017 at 3:26 AM
