Engine runs-on
215,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
EZAUTODIAGNOSTIX
Dear sir, I am in South Africa so the mileage is in kilometers (sorry). This is the 160i model. The engine runs-on when the vehicle is switched off. My scanner cannot access pre-2000 and when i bridge the pins on the diagnostic plug I get no fault codes reading the flashing MIL. This engine does not have a distributor. Timing is regulated by the ECU. I do know that the head gasket was replaced recently.
Any help will be appreciated. Thank you.
I am a qualified Auto-Electrician. (I selected mechanic in the next question)
Sep 26, 2017 at 4:30 PM
  • 55,766 POSTS
It sounds like you have a vacuum leak allowing air to enter the engine after shut down.
Here is a guide to help confirm the problem:
Please run this test and get back to us so we can keep helping you.
Cheers, Ken
Sep 27, 2017 at 7:12 AM
