will 2005 4 cly motor fit and work in 2003 ford edge 4wd with 4.0
Apr 1, 2014 at 12:00 PM
HMAC300
✓Experienced Mechanic
if they are both either front or rear wheel drive engines. there is no 2003 ford edge least in U.s.
Apr 1, 2014 at 11:34 PM
FORD FUN
MEMBER
thank-you they are both rangers 2003 4wd ext cab and 2005 2wd str. will computers match?
thanks for answer ford fun
Apr 3, 2014 at 10:43 AM
HMAC300
you have to use the computer and sensors to whatever vehicle you are putting it in. the sensors have tobe changed because they will need the correct hookups for harness
