Engine will not turn to engage the starter?
180,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
EK69
  • 5 POSTS
Turn the key over motor won't engage the Starter. I replaced the Starter, Battery, and Alternator. Would turn over until last night. Now I hear a "Clank" when turning the key.
Jul 10, 2022 at 10:57 AM
  • 55,732 POSTS
Yep, I would use a breaker bar on the front of the engine to see if the engine turns over because it sounds like the engine is locked up. This guide can help as well:
Jul 11, 2022 at 11:08 AM
EK69
  • 5 POSTS
We did that and it turns. Thank God
Jul 11, 2022 at 9:33 PM
  • 55,732 POSTS
Nice, so the clank you hear is probably the starter Bendix engaging into the flywheel, but the motor part of the starter is not working. can I ask which brand of rebuilt starter did you use?
Jul 12, 2022 at 4:09 AM
EK69
  • 5 POSTS
Altima.
Jul 12, 2022 at 4:41 AM
  • 55,732 POSTS
I would get an AC Delco unit from Rockauto or Amazon. Also, check the positive and negative battery cables. Battery is fully charged? Also make sure the negative cable is connected to the engine block and frame/chassis of the truck.
Jul 13, 2022 at 4:45 AM
EK69
  • 5 POSTS
All connections are good. We have now run into another problem. Fuel pump is now dumping gas into the engine. One problem turns into another.
Jul 13, 2022 at 11:29 AM
EK69
  • 5 POSTS
This is week number 3 of working on it daily so we can go to work.
Jul 13, 2022 at 11:30 AM
  • 55,732 POSTS
Is the ground connected to the engine and the frame/chassis? We should run the codes to see what comes up.
Can you please shoot a quick video with your phone so we can see what's going on, that would be great? You can upload it here with your response.
Jul 14, 2022 at 3:13 AM
