engine wont start and computer wont display any codes
125,000 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
JUSTINTIME
Van was working fine and then I parked it, shut off engine and 15 minutes later I tried to start it again and it wouldn't start. It seems to crank over fine but wont start engine. I tried to check the engine codes but the fault codes display wasn't working either. I checked the coil and distributor cap they don't seem like they are getting any power and I replaced the pcm, looked over the fuses but I cant figure it out.
Dec 12, 2013 at 4:00 PM
  • 110,248 POSTS
Are you getting spark to the plugs? Have you checked fuel pump pressure.
Dec 12, 2013 at 9:08 PM
JUSTINTIME
Im not getting any spark at the plugs as far as I can tell and it doesnt sound like Im getting fuel either.
Dec 13, 2013 at 4:29 AM
JUSTINTIME
I got it working! I had checked everything except for the number 16 fuse on the inside of the van under the dashboard. Thanks I had found the answer on one of your other threads.
Dec 14, 2013 at 5:16 AM
