Car was running bad I was told the air intake gasket needed to be replaced after it was replaced the motor tries running but shuts off.
Sep 14, 2023 at 1:25 PM
✓Experienced Mechanic
The first thing I would do is make sure the electrical connectors are plugged in completely and check for any ground wires that have been left off or are loose when doing the repair. Next, let's check all fuse with the system on.
