Engine cranks but will not start
81,000 MILES • 6 CYL • 4WD • AUTOMATIC
PETEKOTT
Replaced fuel filter, distributor cap and rotor. Getting good spark and fuel pressure at 58 lbs. Sprayed starting fluid in intake and didn’t do much.
Oct 29, 2019 at 5:23 PM
Good morning,
Pressure is barely within specs.
The next thing I would do is a compression test to be sure there no internal engine issue.
Are there any codes stored?
Oct 29, 2019 at 7:56 PM
PETEKOTT
Compression is good and there are no codes. Vehicle was running good before parked for 4 months.
Oct 30, 2019 at 3:22 AM
What is the compression?
Do you have a scan tool to monitor the injectors to see if they are being commanded to allow fuel?
Oct 30, 2019 at 5:40 AM
PETEKOTT
I'll check for scan tool.
Oct 30, 2019 at 5:47 AM
Okay, I still need the compression.
Oct 30, 2019 at 5:49 AM
