Engine will not start
146,000 MILES • V6 • 2WD • AUTOMATIC
MAMIEJARIE
No lights, radio. Won't take a jump. Husband hears a clicking in fuse box.
Dec 21, 2020 at 4:06 AM
  • 110,246 POSTS
First, I need you to check fuse 48 in the fuse box under the hood. See pics 1 and 2. In addition to checking the fuse, confirm there is power in and out from it. Here is a link that you may find helpful:
If the fuse is good and power is flowing, then we need to check two grounds. If you look at pic 3, I highlighted the ground locations. Make sure they are clean, tight, and free of corrosion.
Do this and let me know what you find. One last request. Since he hears a clicking, check to make sure nothing is creating a spark. If there isn't, it is likely a relay. You can try to identify which relay by simply touching them. You will feel the click.
Dec 21, 2020 at 1:29 PM
