Engine turns strong engine will not start, there is no spark.
100,000 MILES • 2.8L • 6 CYL • 2WD • AUTOMATIC
OTHEL
Feb 21, 2018 at 1:56 AM
OTHEL
It was the ignition coil here is the new one started right up
Jun 16, 2021 at 8:38 AM
SQM
  • 6,383 POSTS
Thank you for sharing the fix for the issue that you had.
A faulty ignition coil will stop the spark plugs from producing any spark.
one of the common reason for coil failure is having moisture getting inside the coil and cause corrosion. Which will lead to the coil not functioning properly.
I have attached diagrams for anyone who might be having the same issue.
Dec 12, 2021 at 2:17 PM
