Engine will not start
100,000 MILES • 2.7L • 6 CYL • 2WD • MANUAL
HARRISONDAVE1963
Engine shut off on the road. checked all fuses they are good. Did not check relays. Has a spark from the coil. will not fire even with starting fluid.
May 26, 2019 at 2:34 PM
SCGRANTURISMO
  • 4,897 POSTS
If your vehicle has spark from the coil, and won't start even with starting fluid, your vehicle's engine may have a compression problem. An engine needs only three things to start 1) Fuel(in your case starting fluid) 2) Spark (delivered at the proper time) 3) Compression. If these three things are present an engine has no choice but to start. I have included a few links below for you to go to:
https://www.2carpros.com/articles/symptoms-of-low-compression
https://www.2carpros.com/articles/the-reasons-for-low-compression
Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
May 26, 2019 at 3:18 PM
