Engine will not start
235,000 MILES • 2.8L • V6 • 2WD • AUTOMATIC
SHANE FRISBY
Everything works when I turn the key but the engine won't start. Checked the wires and battery and everything is connected what should I do?
Oct 18, 2019 at 5:24 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Does the starter engage when you turn the key to the start position? If it doesn't, we need to determine if there is power to it or if the starter itself has failed.
Here is a link that shows how to check a starter. Perform these test and let me know the results.
If the starter does engage but the engine fails to start, follow this link:
Let me know if the start is or isn't working and the results of these tests. If you have other questions or need help, let me know.
Oct 18, 2019 at 2:15 PM
