Engine will not crank.it will crank if I bypass the starter relay but will not run with the key in run position. Ignition switch checks good. it is a 45RFE with an internal neutral switch. I do have power at yellow wire with blue stripe at safety switch connection on the transmission with key on. Need some ideas!
Oct 19, 2017 at 6:29 AM
