When I use the jumper cable it starts right away. I let it sit for at least 30 minutes to let it charge not having the vehicle running on the Spektra. My issue is. When I turn off both of the vehicles and I disconnect the jumper cable from the Spektra. There is no power and crank when starting the spectra, but when I connect the cable back. Then it starts right away. I did clean the cable connector and put a new battery. It still gives me the same issue. Please help.
Feb 11, 2025 at 1:33 AM
