Engine won't turn over
119,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
BOBWED
When I turn on the ignition switch I hear a whirring sound, but the engine won't turn over. The lights work, and the seat belt warning chime sounds. Is it the starter motor that is the problem?
Apr 12, 2016 at 8:02 AM
HMAC300
  • 48,601 POSTS
if you hear a whirring sound then the starter is bad have an assistant try to start it open hood and see if starter whirs. it is actually the starter drive is no good or solenoid on starter but you just replace the whole thing.
Apr 12, 2016 at 8:10 AM
