Engine wiring harness
100,000 MILES • 5.7L • V8
CARL ENLOE
I have got a tub 350, I rebuilt it. can I splice in to the tub wires to run wires to the fuel rail eight injectors?
Apr 15, 2018 at 7:32 AM
Good morning.
Do you not have power to the injectors? What is the issue that is causing you to do this procedure?
Apr 15, 2018 at 9:46 PM
CARL ENLOE
I put a 1959 body on a 1994 frame an installing ever thing on that Chevrolet and wanted to change to TPI.
Apr 17, 2018 at 6:25 AM
Okay, to power the injectors you need a twelve volt feed from the fuse box to the injectors. it should only be hot with the key on.
do not tap into anything. run it right from the fuse box.
Apr 17, 2018 at 6:30 AM
CARL ENLOE
Could I toe into the old ton wires an that give me enough fuel pressure?
Apr 17, 2018 at 6:35 AM
CARL ENLOE
Tbi
Apr 17, 2018 at 6:36 AM
for a tuned port you need more than 9 lbs of pressure. you need upwards of 40-50 lbs. you can use the existing wiring from the truck for the fuel pump. that already had a relay for the fuel pump.
Apr 17, 2018 at 6:39 AM
