Engine wiring harness installation
80,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
BRYCE CLINE
  • 32 POSTS
Someone removed the wiring harness and I am trying to find out where the connection for the one I have in picture below. it's the harness that comes around front of engine and ends at the o2 sensors. my only other thought is it's the harness that runs around the core support.
May 19, 2020 at 7:52 AM
  • 110,248 POSTS
If they end at the oxygen sensors, it either goes to the PCM or power. Can you tell me the wire colors?
I attached three pics below. I highlighted where the wires from the sensors ends up. Take a look through them and see if the wire colors match.
May 19, 2020 at 1:30 PM
BRYCE CLINE
  • 32 POSTS
Hi Joe,
Thank you for the schematic. I see what's going on now, the harness that runs below that one is older then 2007. I seen your diagram and what I have to change that lower harness and it has the correct plug that eliminates the one in question cause it plugs into it.
Thank you Joe, greatly appreciated.
May 20, 2020 at 2:42 AM
  • 110,248 POSTS
Happy to help. Let us know if you have questions in the future.
May 20, 2020 at 12:56 PM
