Engine wiring diagram needed
60 MILES • V6 • TURBO • 4WD
OBIORA
  • 10 POSTS
I want to a chat, or video or file on how to identify engine wire base on the color, knowing the location and function.
May 20, 2021 at 11:47 PM
I am providing the complete powertrain wiring diagram. However, I suspect this is not the correct one for your engine due to what you noted on the heading.
We do not have an option for 4WD/AWD Camry in the USA nor do we have a turbo option. So if this is accurate that you have 4WD and a turbo engine then this is not going to be correct for your engine.
Unfortunately we only have manuals for the vehicles that are offered in the USA so if this is not in the USA then unfortunately we don't have this diagram.
Please see below for the diagram that we do have. Please let us know if we can help in other ways. Thanks
May 22, 2021 at 1:14 AM
OBIORA
  • 10 POSTS
Thank you sir am very pleased with the wiring chat, sir and i will love to see more chats on USA modern cars the wiring system showing location and detailed function.e.g Honda, Mercedes, and Nissan.
May 22, 2021 at 6:46 AM
We have all those wiring diagrams and any thing in the service manual for any vehicle made for the USA, so we can definitely help.
However, we need to get a new post started for each issue or request. The only reason is, you may not be the only one looking for them so while we provide them and attached them your posts, others will not find them if they are under other vehicle headings or issues.
So any vehicle that you need, just start a post for it and what you need and we will reply with that info. Here is a link to start a new one:
Thanks
May 22, 2021 at 12:08 PM
