Engine will not start
JMSHORTYFARMER
  • 2001 FORD MUSTANG
  • 3.8L
  • 6 CYL
  • MANUAL
  • 140,000 MILES
I replaced the engine with a 2003 engine, now I am getting gas to the rail but the injectors will not activate. Put new fuel pump in and I can spray gas in the intake and it will run. Fuel pump is kicking on and has pressure. What could it be?
Thursday, April 20th, 2017 AT 9:41 PM
HMAC300
  • 48,601 POSTS
Try a security system reset the battery was disconnected and probably is engaged. See our link. if that does not do it scan for codes to see if something else may be causing it and check all fuse under hood.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Friday, April 21st, 2017 AT 7:02 AM
