Engine cranks but does not start?
155,938 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
1ACCORD
I do have fire, new plugs, new wires, new rotor, new cap, but it won't start, and I do have gas. I left my car at a friend's house because it was leaking from the gas tank. Apon returning and taking the gas tank I had to replace the hose and when I tried to start the vehicle it acted like it wanted to start but it didn't start and then it went, I had it I went through this no start situation. so, I replaced all the things above and it still turns over. I have spark and all the plugs fuel in the carburetor has a single carburetor injector, but it just won't fire it won't catch. I'm trying to figure out what it could be.
Nov 11, 2022 at 7:38 AM
  • 110,251 POSTS
Here is what I suggest: First, see if it starts if you use starting fluid. If it starts and then stalls, we know its fuel related.
Next, I need you to check for diagnostic trouble codes.
Here is a link that explains how to retrieve them on this vehicle:
https://www.2carpros.com/articles/nissan-obd1-diagnostic-trouble-codes-and-retrieval-procedure-1984-to-1994
Let me know what you find.
Note: If you plan to work on the fuel injector for any reason, disconnect the battery. There is power present at all times.
Nov 11, 2022 at 2:35 PM
