Engine will stop running when stopped with air conditioning on.
200,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
COKERAL59
The engine will run fine while moving with the air conditioning on. It will shut off as soon as you come to a stop. I turn off the a/c, restart the engine, and drive away, then turn a/c back on. It runs fine until I stop, then it will shut off again.
Jun 6, 2014 at 12:27 AM
  • 110,248 POSTS
Either you have a vacuum leak or the idle air control valve (IAC) is bad.
Jun 6, 2014 at 2:22 AM
COKERAL59
I was thinking maybe a voltage regulation problem. I will check it all out. Thanks very much.
Jun 6, 2014 at 5:09 AM
  • 110,248 POSTS
Why do you say voltage regulator? Is the battery light coming on?
My belief is the idle air control valve (IAC) is the issue, but like I said, a vacuum leak can cause the issue too. The IAC is responsible for maintaining the engine idle speed. With the AC on, there is an added load on the engine. As a result, the computer should adjust the IAC to compensate for the extra load. If the IAC isn't working properly, the engine may stall at an idle.
Jun 6, 2014 at 12:57 PM
COKERAL59
Thanks again, I guess I was fishing for a cause with the voltage regulator idea.
I'm going to check the IAC and the vacuum lines today.
Jun 6, 2014 at 10:01 PM
  • 110,248 POSTS
Let me know what you find.
Jun 7, 2014 at 12:44 PM
