Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Escort
Engine
Symptoms
Not Running
engine will not start
1999 FORD ESCORT
99,542 MILES • 3.0L • 6 CYL • TURBO • 4WD • AUTOMATIC
JOHN RONALD CHAPMAN
MEMBER
1 POST
the engine will not start, want to check fuel pump relay.
Feb 2, 2021 at 11:02 PM
SEVAG P
Experienced Mechanic
hello.
Ford Escort 1999 turbo is 4 cylinder 2.0L engine no v6 turbo, check the diagram below figure 1 for fuel pump relay location.
check figure 2 below procedure how to check fuel pump relay.
check our link below how to check relay and how to test a fuel pump.
Let us know if you need more help.
thank you.
Images (Click to enlarge)
Feb 4, 2021 at 2:58 AM
JOHN RONALD CHAPMAN
MEMBER
1 POST
That car does not look like an Explorer?
Feb 5, 2021 at 2:33 AM
that is because you listed Escort as your car?
Feb 5, 2021 at 2:35 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
