I must accelerate the engine above idle to keep it running. If I release the gas pedal it shuts off. I had a P1401 code, I replaced the EGR Pressure Feedback Sensor and it cleared the code. Could the Idle Air Control Valve be at fault?
The issue began after I cleaned the Mass Air Flow Sensor. I used the CRC MAP aerosol cleaner while running the car. Prior to the cleaning the car idled a little rough and would stall out.
(2.0 Liter ZETEC Dual Overhead Cam)
Can you advise please? thank you
Rene Contreras
Rene Contreras
Apr 30, 2019 at 11:44 AM
