Engine will not crank over
249,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
TREVOBOY
4.0L sohc v6 engine. so today my truck started and drove fine. i got in it this afternoon and started it and it started with an ideal of around 3,000 rpm's. i drove it about half a mile stopped turned off the engine and tried to start it again and it is dead got nothing; no crank over no clicking. battery is fully charged, got dash lights,, headlights, radio all work fine. The engine i got nothing though. any ideas on where to start looking will help me a lot right now. Thanks
Jul 26, 2019 at 1:38 PM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with Maxi Fuse #5(50A) in the Battery Junction Box of your vehicle which is located near the battery. In the diagrams below I have included a wiring diagram of your vehicle's starting circuit as well as a diagram of the location and the Battery Junction Box with callout. I have also included this link below for you on how to properly check and replace a fuse if you are unfamiliar with how to do it:
Please go through these guides, if necessary, and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jul 26, 2019 at 5:33 PM
TREVOBOY
K so i checked all the fuses under the hood and in the cab all are good starter relay tested good all around kt does have a tiny bit of resistance only like .5 i pulled the starter off and bench tested and every thimg engaged fine i have power going through the solenoid next to the battery i broke down and bought a obd 2 today plugged it in and all i got after the scan was ( cant connect to the power train of the vehicle) the fuse is good for the PCU and i have power to everything when the key is in the on poss. I can hear the fuel pump kick on the relays click got dash lights headlights im spinning my head around this i cant figure out what is going on if the ignition switch was bad would i still get power to everything. Also i did try jumping the starter with the battery i got spark of course but nothing else and i read that if i jumped it like that regardless it should start ?
Jul 28, 2019 at 2:33 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Okay, so when you jumped the positive post on your starter solenoid, did the starter crank the engine?
Thanks,
Alex
2CarPros
Jul 28, 2019 at 3:15 PM
TREVOBOY
No i just got spark off the terminals and nothing else...
Jul 28, 2019 at 3:33 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Okay, then that's your problem. The starter is no good, or more specifically, the bendix gear in the starter has failed. If you did it correctly, there should be no reason, other then a broken or bent flywheel/flex plate that the bendix shouldn't have engaged. Please double check that you put power to the positive post of the starter solenoid and if the starter doesn't engage and crank the engine, then it will need to be replaced.
Thanks,
Alex
2CarPros
Jul 28, 2019 at 4:11 PM
TREVOBOY
Ok thank you for your advice. If you dont mind me asking one more question i just bought a obd2 today from harbor fright plugged it in ran a scan and came back with not connecting to power train and said no codes are stored in the freeze frame.. i checked the pcm fuses and they are good any ideas why it wont connect or read codes after the scan?
Jul 28, 2019 at 4:43 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
In the diagrams down below I have included the factory diagnostic troubleshooting pinpoint test NB for your vehicle's Malfunction Indicator Lamp(MIL) or "check engine" lamp. Please go through the guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jul 28, 2019 at 9:23 PM
MIRIHAROSE
my 99 explorer won't turn over unless i jump it. i just put a new battery and alternator in it and the problem still exists.
Dec 31, 2020 at 12:56 AM (Merged)
OBXAUTOMEDIC
  • 3,713 POSTS
Hello, Ok, look for the part below, it should be near the battery... https://www.2carpros.com/images/external/101346.jpg Using a screw driver or something with an insulated handle, connect the 2 large terminals. If vehicle turns over replace it (Starter Relay Switch NAPA Part Number ST404). These guides can help us fix it https://www.2carpros.com/articles/starter-not-working-repair and https://www.2carpros.com/articles/car-battery-load-test Please run down these guides and report back. .
ED FARMER
every thing was fine when my wife turned the key off,but would not crank back.no fire to coil pack shop put it on computer,no codes were shown c/o cam position sensor, still no fire to coilpack. electric fuel pump was working..he had a old e.m.c around shop. pluged it in motor started for a sec..he would like to put a new ecm on it but im not so sure.they rarely fail my themselves maybe a ground fault?
  • 31,937 POSTS
Hi there,
See if your mechanic has a contact with one of the electronic repairs who do ECU's they often (here anyway in Australia) have test units that you can try on your car, if it doesnt fix the problem there is a small service charge, and if it does, well your all done.
This guide can help
Mark (mhpautos)
BILL CARROLL
  • 5 POSTS
Hello everyone. My SUV (Eddie Bauer) sat in the garage for the last two months. It had been running fine. When I went to start it up the other day, it would not crank but fired right up when I jumped it. I drove it the next day for a while and all was fine.
Today I went to start it and it would not turn over. I tried jumping it again but it would not start. I took out the battery (it was about due to be replaced) and took it to AutoZone (they tested the battery and said it was bad) and bought a direct replacement. When I installed the new battery, it cranks great but will not start. Lights and everything all work normally.
I have done some research and found out (?) that this may be the result of the anti-theft system needing to be reset? The battery was out of the car for about two hours.
The car has also been parked on a slight incline in my driveway (about fifteen degrees, so the front end is higher than the back end) and has about a quarter tank of gas. Could this have anything to do with it?
Dec 31, 2020 at 12:57 AM (Merged)
CARADIODOC
  • 34,414 POSTS
The better suspect is some fuses blew from the current surge when the new battery was connected.
Fuel is not the problem. There should be a small bowl in the tank that the fuel pump and pickup sit in. That bowl is kept full so the engine does not stall when the gas runs to the side of the tank when cornering with low fuel level.
BILL CARROLL
  • 5 POSTS
Thanks, have not considered that. I jumped the car a few times and got it started before the old battery just gave up. Why would a new battery blow any fuses? I hope you are right but it just seems odd.
CARADIODOC
  • 34,414 POSTS
That is very common. The engineers have seen fit to hang an unnecessary, unreliable, complicated computer onto every part of our cars. They all have memory circuits that draw a constant current to keep them alive. When connecting a battery, and sometimes when connecting jumper cables, there is a current surge when those memory circuits charge up. Also, some computers, by default, try to run things like pumps and solenoids, as soon as they see the twelve volts applied to them, then they go to "sleep" mode until they get a wake-up signal from the body computer or the ignition switch. All those things turning on at once can draw a current spike that is enough to blow some fuses.
BILL CARROLL
  • 5 POSTS
Well, get this. After much consultation (and checking all the relays and fuses), I decided it must be the fuel pump so I found a reputable garage and called for a tow. The tow truck guy arrived and was figuring out how to get the Explorer off my inclined driveway (about 15 degrees) when he said, "I used to have one of these. Let me try something."
He put it in neutral and rolled it out onto the flat street and guess what? It started right up. He figured with less than 1/4 tank of gas and the cold weather, etc. et al, somehow the gas wasn't getting to the fuel pump. I drove it around for a while, restarted it, all good. It needs a good tune up and the steering wheel shimmies when turning (which I discovered is caused by air in the power steering fluid).
The only thing that bothers me is that the Explorer has been parked on this same incline (nose up) a million times and never had trouble starting. I'm hoping that the two months it sat in the garage and the extreme cold we had for a while were the cause of the problem.
Thank you all for your help and patience.
CARADIODOC
  • 34,414 POSTS
Dandy. Let me share what I learned about how this works on my '88 Grand Caravan. Fuel coming into the tank from the engine on the fuel return line does not dump into that bowl the pump sits in, as you would expect. Instead, it flows up a ramp alongside the outside of the bowl, then washes into the bowl. The venturi action draws gas from the tank along with it, and it's that gas that keeps the bowl full. Knowing that, if the fuel level is real low, when parked on an incline, there won't be any to get pulled into the bowl. Only the returning gas will flow up the curved ramp and go into the bowl, but a large percentage of that will just run to the lowest point of the tank. In my gas tank, that bowl only holds about a quart of gas. If the engine idles too long while on an incline, the bowl will run empty. The good news is unlike with an older mechanical fuel pump that has to suck gas all the way to the front of the vehicle, an electric pump will start to pump gas right away once the truck is on level ground and fuel spills into the bowl. The thing to keep in mind is it's that returning gas that draws all the gas into the bowl. Were it not for that, no gas would spill into the bowl to keep it full once the tank got down to about a half tank.
As a point of interest, I found the fill pipe dumps gas right into that bowl, so if I run out, it just takes a half gallon to get going again. On the '94 Grand Voyager I'm driving now, that appears to be not the case. When I run it empty, (on purpose), I have to add almost five gallons before the engine will start. I assume that is because it needs to get high enough to spill over into the bowl. You should remember that too if this happens again. If you have, . . . lets say, . . . only one gallon left in the tank, and you're on an incline, only some of the fuel coming back on the return line will go into the bowl. Once that is used up, even coasting to level ground won't do it. There won't be any returning gas to pull additional gas into the bowl. You will likely need to pour in a good half gallon, and if that doesn't work, add a bunch more before you go looking for other causes.
As a second comment of value that may or may not be related, when I worked for my cousin in his tv repair shop, he was buying Ford vans every few years, and the dealer finally told him to not even bother complaining about the fuel gauge, . . . again. "That's the way they are" they told him. His grump was there was about seven gallons left in the tank when the gauge read "empty". Later I learned they did that to insure the pump motor was always sitting in gas to cool it. People who habitually run the tank close to empty had a higher incidence of pump failures, so they modified the sending unit so people would add gas before the level got too low.
Happy to hear yours is solved. Come back and see me again.
BILL CARROLL
  • 5 POSTS
I learn something new every day, that's for sure. I've only lived with the inclined driveway about a year, but it's a constant vehicle rodeo (we have three cars) getting in/out of the garage. Typically the Explorer winds up in the driveway but NOT at the bottom, but near the top where it's almost flat. I guess it's just dumb luck that it hasn't happened before! Thanks again.
  • 55,711 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers, Ken
BILL CARROLL
  • 5 POSTS
And in addition to the tune-up it needed a master cylinder and armature ... ugh. Runs like a top now!
MIQUELFLECHA
The truck wont start, when the key is turned, there is a rapid clicking sound. The battery is 2 days old, I took the starter in to be tested and it's fine. I cleaned the battery connections. I have hooked it up to jumpers and the same problem occurs, A rapid clicking. What else could it be?
CADIEMAN
  • 3,544 POSTS
this is caused by a low battery or a bad connection.you will need to check the voltage at the battery and on the positive terminal on the starter.both should read over 12 volts on a meter.
MIQUELFLECHA
My negative cable was corroded inside, I clipped the bad portion and reattached it and it fired up. Thank you
CADIEMAN
  • 3,544 POSTS
np happy motoring
QUINTON GOODWIN
I have a 99 Ford Explorer and Im having trouble with the starting system somewhere. It does not crank after I have driven it. When I get back into the car and turn the key I get nothing. Not even a click. After sitting for about an hour it cranks up fine. What seems to be the problem?
Dec 31, 2020 at 12:58 AM (Merged)
JGAROFALO
  • 489 POSTS
[quote:0c3ec70fef="Quinton Goodwin"]Electrical problem
1999 Ford Explorer 6 cyl Two Wheel Drive Automatic 140000 miles
I have a 99 Ford Explorer and Im having trouble with the starting system somewhere. It does not crank after I have driven it. When I get back into the car and turn the key I get nothing. Not even a click. After sitting for about an hour it cranks up fine. What seems to be the problem?[/quote:0c3ec70fef]
The problem appears to be temperature related. A starter relay comes to mind as a good place to start. When the car is acting up, use a test light, and check for voltage on both sides of the starter relay. Also check for voltage at the SMALL wire on the starter while a helper turns the switch to the START position. If ther eis voltage getting to the starter, then the solenoid is the problem.
Also, do not overlook obvious items like clean and tight battery terminals.
WILLIAM RIDENOUR
My vehicle has eaten two starters over this weekend it ate my second starter it won't start. I had to shim my second starter and that held out for about a month it would do the the rapid metal thing like the gear on the starter wasn't disengaging. I shamed it that stopped and then all the sudden it it's not even starting now.
  • 110,248 POSTS
Welcome to 2CarPros.
At this point it's not starting. What is happening? Does the starter grind when you try? Does it do nothing? Does it spin but not turn the engine?
Since you have been having issues, I'm starting to question the flywheel itself. It may be damaged or even cracked.
Here is a link that shows in general how to replace the starter. Take a look and see if there is anything that you may have missed.
Next, here are directions that show how to check the starter and flywheel. Pictures 1 and 2 correlate with these directions,
STARTER DRIVE/FLYWHEEL RING GEAR INSPECTION
1. Remove the starter motor.
pic 1
2. Check the wear patterns on the starter drive gear and the flywheel ring gear. If the wear pattern is normal, install the starter motor.
pic 2
3. If the starter drive gear and the flywheel ring gear are not fully meshing and both of the gears are scored or damaged, replace the starter motor. If necessary, replace the flywheel.
___________________________________________________
Here are the manufacturer's directions specific to this vehicle. Take a look through them also. The remaining pics correlate with the directions.
REMOVAL
WARNING: WHEN PERFORMING MAINTENANCE ON THE STARTING SYSTEM BE AWARE THAT HEAVY GAUGE LEADS ARE CONNECTED DIRECTLY TO THE BATTERY. MAKE SURE PROTECTIVE CAPS ARE IN PLACE WHEN MAINTENANCE IS COMPLETED.
1. Disconnect the battery ground cable.
2. Raise and support the vehicle.
pic 3
3. Remove the starter motor solenoid terminal cover.
pic 4
4. Disconnect the starter wires.
1. Remove the nuts.
2. Disconnect the wires.
pic 5
5. Remove the nut and the starter ground cable.
pic 6
6. Remove the bolt and the starter motor.
INSTALLATION
pic 7
pic 8
pic 9
1. Follow the removal procedure in reverse order.
NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
If this isn't helpful, let me know the specifics.
CHARLIE MARTIN
when i try to start the engine sometimes it sounds like its dragging
Dec 31, 2020 at 12:59 AM (Merged)
  • 110,248 POSTS
If the starter sounds like it is turning slower than it should, start by taking the vehicle to a nationally recognized parts store and have them load test the battery. If the battery is good, have them check the starter draw when trying to start. It may be going bad and pulling too many amps.
Let me know what you find.
PS: Most parts stores will do this for free.
