Engine will not crank but if I jump the starter solenoid it will run. I replaced the ignition switch but it still will not crank. When I probe the cabin fuse block there is no power at fuse 5 (ignition run power feed) , fuse 6 (brake shift interlock,ECM) and fuse 20 (starter motor relay).
I have checked fuses 101, 105 and 116 in the engine bay fuse block and all are okay. Any help to fix my problem would be greatly appreciated.
Apr 28, 2020 at 4:13 AM
