My Ram Van 250 with a 318 ci engine was idling fine a few weeks ago then began to sputter and died. I thought it had ran out of gas but that's not the case.
I suspected the ECM (been replace 4 times!!) so I had sent it out for testing....they found 'leaking caps' and I had them refurbish and test it. Did not fix the problem.
I also replaced the ASD relay....did not fix the problem.
I checked the coil....tested within specs. I have 9 volts at the coil when cranking....have a new battery.
I also checked the voltage at the Throttle position sensor....has 5 volts when ignition is 'on' so computer is getting a signal apparently.
I had previously had the van die on me once and a fuse link wire melted....replaced it with a circuit breaker setup that's worked fine over the years. It was not blown and is functioning.
I am at a loss as to why it will not start. I have no spark. Checked the distributor and it seems okay. I understand that the Crank Position Sensor could be an issue....is there a simple test for this component?
Otherwise I am at a total loss as to why it won't start. It is definitely electrical in nature as I have fuel and the fuel system pressurizes when the key is in the 'on' position.
Thanks for any help you can send my way! RW
Sep 26, 2013 at 4:06 AM
