Engine weeping and shaking
55,000 MILES • 1.4L • 4 CYL • FWD • AUTOMATIC
EREKLE KINKLADZE
a month ago I noticed car shaking when standing on one place with my Gear in D, 1, 2 or R and a while ago i noticed strange weeping sound that is coming out from throttle. Here is my video.
https://youtu.be/MjXzXDjukAg
Jun 20, 2016 at 2:40 AM
CARADIODOC
  • 34,415 POSTS
Shaking is due to a misfire. The most common cause is worn spark plugs and wires.
Jun 20, 2016 at 12:40 PM
EREKLE KINKLADZE
i changed spark plugs recently and i will change the wires as well but i think the problem is different because it has the weeping noise. i also changed my air filter and cleaned throttle but that does did not help
Jun 20, 2016 at 3:09 PM
  • 55,781 POSTS
Hi there!
The weeping sounds sounds like a vacuum leak, here is guise that can help you find it
Please let us know what you find
Best, Ken
Jun 22, 2016 at 2:20 AM
