I noticed water leaking from which I thought was the lower radiator hose. So I changed the lower radiator hose. Water is still leaking. So then I thought well it must be coming from water pump. So I changed water pump. This is the second time I changed water pump within maybe just a little over a year ago. After I put new water pump in my vehicle and had everything back together I started putting water into radiator and within like three seconds I seen water leaking out and it was coming from the same exact area. And the water seemed to be leaking out pretty fast. It was not leaking out straight down. It seemed to be leaking out and then maybe running down onto whatever is down there and drips off all across somewhere by or near or underneath or maybe somewhere above water pump area. And it did not seem to be leaking as fast before I changed water pump. So help please.
Jul 31, 2017 at 9:11 AM
