i replaced 6 spark plugs and high tension wire....still warning lights on.... i noticed that one of the ignition coil was busted... i replaced it with new one, at first it works but after a minute of engine running the same ignition coil busted again.... what seems to be the reason of the damage wherein new ignition coil was replaced
Jun 17, 2013 at 10:50 PM
