Engine warning light?
99,000 MILES
COLIN KENT
Light keeps coming on goes off using obd but will come back on after a day.
Sep 9, 2024 at 2:12 AM
  • 55,748 POSTS
What is the code that is stored? Here is a guide to help please get back to me so I can help you fix it.
Please go over this guide and get back to us.
Sep 9, 2024 at 2:32 AM
COLIN KENT
It says to lean bank 1.
Sep 9, 2024 at 2:41 AM
  • 55,748 POSTS
Can I get the code number, also what is the engine size?
Sep 9, 2024 at 4:58 AM
COLIN KENT
1.6 Bank 1.
Sep 9, 2024 at 6:47 AM
  • 55,748 POSTS
This can be one of 3 things in most cases, the fuel pump is weak, you have a vacuum leak or the weak MAF sensor. Here is a guide to help you go over the repairs and get it fixed:
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Sep 9, 2024 at 9:01 AM
