Engine warning light
77,000 MILES • 2WD • MANUAL
QUICKLEARNER
Fitted new oxygen sensor problem seems to be solved. diagnostics state no other problems. but warning light comes on after re setting.
Jun 5, 2019 at 2:37 AM
  • 110,251 POSTS
Welcome to 2CarPros.
If the light is coming on, is it the same code as before you replaced the sensor? Can you let me know what the code is? When you say warning light, are you referring to the check engine light?
Often times a code related to a sensor will be indicated, but the problem isn't the sensor, but rather it ends up being a damaged wire or connector.
Let me know what the code is so I know which direction to run with this.
Jun 5, 2019 at 2:14 PM
