Engine warning light
1999 FORD
200,000 MILES • 5.9L • 6 CYL • TURBO • 2WD • MANUAL
FOUR HAND MAN
Engine warning light comes on and I have a loss of power. how do you get to go off?
Sep 27, 2016 at 8:47 AM
CARADIODOC
  • 34,414 POSTS
You read and record the diagnostic fault code(s) to determine which circuit to look at, diagnose the cause of that code, fix the cause, then erase the code. You never want to "get" the light to turn off. It is telling you there is a problem that needs to be solved.
Sep 27, 2016 at 9:30 AM
