engine want to stall when put in drive
1996 CHEVROLET CAPRICE
96,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
JOE1953
  • 806 POSTS
the engine will start and run ok at idle but when put the gear shift in drive the engine want to cut of and stall what could be causing this problem?
Sep 16, 2015 at 3:15 PM
WRENCHTECH
  • 20,761 POSTS
First eliminate all vacuum or air leaks in the system (very important)
. You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
Sep 16, 2015 at 7:13 PM
JOE1953
  • 806 POSTS
the engine idle ok but when put gear shift in drive the engine want to cut of and the engine have a misfiring and the check engine light is on.
Sep 17, 2015 at 12:50 AM
WRENCHTECH
  • 20,761 POSTS
That's information you should have put in your question in the first place. When you ask half a question, you get half an answer. You need to have the codes read and post the numbers here and we'll go from there.
Sep 17, 2015 at 1:07 AM
