engine turns off
32,000 MILES
CHALSONM
the engine turns off when running down hills in ac even though the gear is downed to second or third.the problem prevails only when driving with ac ,otherwise no problem
Apr 28, 2013 at 8:54 PM
KHLOW2008
  • 41,812 POSTS
Check the IAC and idling speed with A/C on and off. If it is too low, you need to have the IAC and throttle cleaned.
Apr 28, 2013 at 9:04 PM
CHALSONM
Thanks.sir what do you mean by IAC
Apr 29, 2013 at 4:27 PM
KHLOW2008
  • 41,812 POSTS
Idle Air Control valve.
Apr 29, 2013 at 10:22 PM
