Engine cranks but will not start
150,000 MILES • 4 CYL • 4WD
RICK G. ESTEBAN
it started before, i did some work on it. like installing an auxiliary horn while the driver side door open while i was working on it. not sure if it drain the battery or not. it's my daughters vehicle and she's in Washington and I'm in California. kind of hard to help her that far away. I don't want her to walk to school even it's just a mile away, she's in college.
Sep 15, 2021 at 5:46 AM
SQM
  • 6,383 POSTS
Any time you are faced with no starting issue, it is a good idea to start with the basics.
Have you tried to jump start it?
A weak battery can allow the starter to click but will not turn the engine.
https://www.2carpros.com/articles/how-to-jump-start-car-battery-using-jumper-cables
Does the engine click when you try to start the vehicle?
Or does it crank over several times but does not start?
If it cranks but does not start, then it could be due to not getting fuel or spark.
In that case you will have to check for spark to the coils as well as check the fuel pressure.
Sep 15, 2021 at 4:29 PM
