Engine turns but will not start
200,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
IR472
  • 15 POSTS
Truck running fine and went to turn around to park and noticed a small noise and that it had lost a little power when reversing then going forward maybe drove like 30 feet after and parked. I did not hear any other noise and turned it off. I tried to start it back and it failed since then.
Went through the initial checklist compression, fuel, and spark and it all check outs. Spark is there and the fuel pump is turning on and the injectors are spraying even added extra fuel in the TB and it did not start.
I put a new ICM hoping it would help but it did not.
I had previously changed the ignition switch about a year ago when it did something similar. (the dash lights turn on when I turn the key to prime the pump so I don't think its the switch again).
could it be an ignition coil?
Jun 21, 2019 at 3:14 AM
Good afternoon,
What was the compression?
If you have spark and fuel pressure, did you check the actual pressure, then it is not a module or ignition switch.
Jun 21, 2019 at 5:18 AM
IR472
  • 15 POSTS
Update: adding some more information.
I got a better crank after letting it sit overnight, so at a certain point it is getting flooded with fuel from trying it.
Also, I unplugged the connector from the computer to the ignition control module and it started up but was pretty weak and shut off after a couple seconds. I tried it again plugged and unplugged ICM and the truck started up with it unplugged for a few seconds.
Jun 21, 2019 at 5:21 AM
Does not make any sense if you unplugged the module. It would have no spark and will not run.
Jun 21, 2019 at 5:35 AM
IR472
  • 15 POSTS
The ICM has two connections one to the computer and one to the ignition coil. From what I understand the spark should not be affected by unplugging the ecm connector.
Does that mean anything aside knowing that the icm is working?
Jun 21, 2019 at 5:50 AM
I know how the ICM works. Yes, it is effected by unplugging the ECM.
You very well may have a bad ECM. Common on the OBD1 series. That is the only thing that makes sense here.
Jun 21, 2019 at 6:00 AM
IR472
  • 15 POSTS
Thanks for your help so far. I will start looking at fuses/relays first then wiring as far as I can follow to see if that could be making the ecm not work properly.
Jun 21, 2019 at 10:28 AM
Diagram for you of the ECM.
Jun 21, 2019 at 10:36 AM
IR472
  • 15 POSTS
Update: Truck still wont start on its own, but it will start if I give it some gas as it turns.
Idle is very weak it almost turns off but it'll maintain when I step it on the gas it reacts on time. There is a code but I am lacking an OBD1 and the old paper clip trick isn't working.
Jun 24, 2019 at 11:07 AM
Okay, from your description, it sounds like the ECM has failed. It controls the injectors and could also be the reason you cannot get it to communicate.
Replacement of the Electronic Control Module (ECM) consists of a service controller, without a PROM (CAL-PAK).
If the diagnostic procedures require the ECM to be replaced, the ECM, PROM (CAL-PAK) should be checked for the correct part number. If they are correct, remove the PROM (CAL-PA K) and install them in the service controller. The service controller will not contain a PROM (CAL-PAK).
IMPORTANT: When replacing a production ECM with a service controller, transfer the broadcast DTC and production ECM part number to the controller label. Do not record information on the access cover.
NOTE: The ignition must be "OFF," when disconnecting or reconnecting the ECM connector, to prevent internal damage to the ECM.
NOTE: To prevent possible Electrostatic Discharge damage to the ECM, Do Not touch the connector pins or soldered components on the circuit board.
REMOVE OR DISCONNECT
1. Negative battery cable.
2. Glove box panel.
3. Mounting brackets and/or retainers.
4. PCM from tray.
5. PCM harness connectors.
6. Access cover and PROM (CAL-PAK).
INSTALL OR CONNECT
1. PROM (CAL-PAK) and access cover on new PCM.
2. Mounting brackets and module(s).
3. PCM into tray until clips lock.
4. PCM harness connectors.
5. Glove box panel.
6. Negative battery cable.
7. Perform functional check.
Jun 24, 2019 at 7:35 PM
IR472
  • 15 POSTS
I did run a fuel pressure test and got 11 psi going to the injectors. It looks like the pump checks out and will start looking at the ECM.
Jun 26, 2019 at 12:35 PM
Okay.
Jun 26, 2019 at 2:49 PM
IR472
  • 15 POSTS
Late Update:
The ECM was the problem. Bought a used one off of ebay and swapped in the prom chip and the truck feels as good as new. It might have fixed up some other issues also, it feels like it is shifting a lot smoother.
Symptoms:
-Crank but no start (fuel,spark, and compression checked out).
-Eventually started by stepping on the gas while cranking.
-Low idle under under 500 RPM.
-Engine would rev but once I let off it would die out or almost die out the return to the 500 RPM.
-Noticeable loss of power when taking off from a stop.
-Check Engine light was ON but would not show the code.
Hope this helps anyone who is going thru the same thing.
Thanks for the help asemaster.
Jul 19, 2019 at 9:20 AM
Sounds like the idle air control on the throttle body. A common failure for all those symptoms.
Jul 19, 2019 at 9:44 AM
