Engine turns but no start
20,000 MILES
ADAM9
Ran out of gas, refilled, turned car off wouldn't start.
May 2, 2020 at 12:39 AM
HARRY P
  • 2,292 POSTS
When you refilled it, how much did you put in? A gallon or two may not be enough to prime the system. You should put in at least 1/4 tank worth (~4 gallons). Then you have to prime the fuel system to get the air out of the lines. To do this, simply turn the key on to the run position for 2 seconds, then off. Repeat 9 more times. Then try starting the car. If it still won't start, prime it again and then try it.
Let me know what happens and we'll go from there.
Sep 28, 2020 at 6:31 AM
