Engine turns but no start
ADAM9
  • 2005 HONDA ACCORD
  • 20,000 MILES
Ran out of gas, refilled, turned car off wouldn't start.
Saturday, May 2nd, 2020 AT 7:39 AM
HARRY P
  • 2,292 POSTS
When you refilled it, how much did you put in? A gallon or two may not be enough to prime the system. You should put in at least 1/4 tank worth ( 4 gallons). Then you have to prime the fuel system to get the air out of the lines. To do this, simply turn the key on to the run position for 2 seconds, then off. Repeat 9 more times. Then try starting the car. If it still won't start, prime it again and then try it.
Let me know what happens and we'll go from there.
Monday, September 28th, 2020 AT 1:31 PM
