Engine troubleshooting codes P0300, P0301 and P0335
62,000 MILES • 1.0L • 3 CYL • 2WD • MANUAL
SIMBAD
The engine shakes to much on idle.Pedal test results P0300, P0301, P0335. One time engine shut of on idle.
I'm not sure to change or not the crankshaft sensor.
Jun 5, 2020 at 7:13 AM
  • 55,603 POSTS
It sounds like you have low compression on one or more cylinders. To be sure lets rundown this guide:
This guide can help as well:
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Jun 6, 2020 at 4:09 AM
SIMBAD
Hi, Ken according your response, I sent you a video of my engine that shakes on idle. Maybe you didn't took this. I sent you again this video.
thank you
Simbad
Jun 20, 2020 at 5:07 AM
  • 55,603 POSTS
I only see the one response. does the engine seem to have good power? It looks like we might have an internal engine problem but to be sure lets remove the spark plugs and do a compression test. here is guide to help you:
Jun 22, 2020 at 3:14 AM
