Engine trouble
185,666 MILES • 4 CYL • AUTOMATIC
ALEYVA1977
The car still starts and drives but the issue is the water is returning to the reservoir. I replaced the thermostat like the mechanic said.
Oct 22, 2019 at 4:51 AM
Good afternoon,
The thermostat is not the issue.
You either have a failed head gasket or a bad water pump not circulating coolant in the engine.
https://www.2carpros.com/articles/water-pump
Is the car overheating?
Oct 23, 2019 at 5:03 AM
ALEYVA1977
I would say no. Gets hot but no overheating. Got a code P0118, Engine coolant temperature sensor circuits high.
Oct 23, 2019 at 1:15 PM
Okay, I attached the possible issues for the 118 but it has nothing to do with the coolant backing up. It is warning you the engine is hot only.
Oct 23, 2019 at 7:39 PM
