Engine tries to start, let the key go and it shuts off
288,247 MILES • 6 CYL • 2WD • AUTOMATIC
TERRYBME
Engine tries to start, but when the ignition key is turned to start it starts, let the key go and it shuts off.
Dec 12, 2019 at 12:44 AM
  • 110,248 POSTS
If it starts with the key in the start position and then stalls when you release it to the run position, I suspect the ignition ballast resister is bad. Power to the ignition bypasses the resister in the start position. When you release the key to run, voltage is reduced to the ignition through the resister. If it is bad, power is shut off to the ignition.
Check that and let me know. It should be located right near the ignition coil.
Dec 12, 2019 at 12:53 PM
