engine transplant
1981 TOYOTA PICKUP
70,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
FIRSTHD
  • 17 POSTS
I live in California, is it possible to change my engine to a bigger one with out much problems or expense?
Aug 11, 2016 at 4:35 PM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Any engine conversion will not be cheap and you also have to take into consideration local laws the may cover such conversions, i can't say how much it will cost or what problems you will face but i can say do your home work first because you can spend a lot of money and get nowhere fast doing this type of job if you are not prepared.
Aug 14, 2016 at 4:32 AM
FIRSTHD
  • 17 POSTS
Thanks for the advice. Firsthd
Aug 14, 2016 at 5:53 AM
  • 31,937 POSTS
Ok good luck if you go ahead with a project just do all the research first check conversion forums for you make and model they often have good advice as they have been there already and know the pit falls
Aug 14, 2016 at 5:57 AM
FIRSTHD
  • 17 POSTS
alternate solution is simple but expensive, buy another, thanks
Sep 5, 2016 at 2:35 PM
RACEFAN966
  • 5,029 POSTS
Smog will be the issue as it needs to pass the yr of the car or engine which ever is newest.
Nov 7, 2016 at 5:30 PM
