Engine/transmission problem
256,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
MATTHEW MACLEAN
Hi there, when i am driving my car normally it shifts fine, but when i give it or put the gas pedal to the floor it is like its almost grinding but it still shifts though. It is right before it shifts to second gear when this happens. It makes almost like a buzzing sound. I don know maybe this could be my transmission or my engine? I would like to find out what this problem is. Thank you
Feb 2, 2017 at 2:14 AM
HMAC300
  • 48,601 POSTS
more than likely if it only does it in one gear it is the transmission. have a transmission professional check it out as it could be a few things internally.
Feb 2, 2017 at 10:57 PM
