Timing chain cover bolts torque specs?
2016 TOYOTA CAMRY
198,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
can you get me the torque specs for these? Timing chain cover bolts. There are different sizes on there. Also, the tensioner 2 10 mm bolts spec Also the guides bolts spec
Thanks
Sep 5, 2025 at 9:38 AM
  • 55,433 POSTS
For the timing chain cover
Bolt A (10 mm head) 9 Nm / 80 in-lbf (7 ft-lb)
Bolt B (12 mm head) 25 Nm / 18 ft-lb
Bolt C (14 mm head) 55 Nm / 41 ft-lb
Cover Nut 11 Nm / 8 ft-lb
Timing Chain Tensioner
8 ft-lb
Timing chain guide bolts: 14 ft-lb
Let us know if you need anything else.
Sep 6, 2025 at 9:25 AM
BHAMDOC1973
  • 2,007 POSTS
can you also provide the timing chain cover bolts tightening sequence?
Sep 11, 2025 at 12:52 AM
  • 55,433 POSTS
Sorry, they don't show that in Alldata.
Sep 11, 2025 at 2:42 AM
