Ticking noise coming from the engine?
190,000 MILES • 3.0L • 6 CYL • AUTOMATIC
NO_SLEEP
When I turn on the car the ticking starts right away and continues while idling, when i press down on the throttle the speed of the ticking noise increases with the throttle I give. I really don’t know what it could be. I replaced the oil and filter, I’m new to cars so any info helps.
Jul 9, 2023 at 3:26 PM
  • 55,548 POSTS
It sounds like you have a lifter or roller follower that has gone bad. can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response.
Please go over this guide and get back to us.
Jul 10, 2023 at 5:30 AM
NO_SLEEP
Hope this video helps clarify.
Jul 10, 2023 at 7:54 AM
  • 55,548 POSTS
Thanks for the video. That is definitely lifter/valve train noise. This could be wear on the camshaft or you have to adjust the valves. Let's remove the valve cover for inspection. Here are instructions on how the job is done in the images below. Can I ask what weight oil you used when you did the oil change? Check out the images (below). Please let us know how it goes
Jul 11, 2023 at 3:36 AM
NO_SLEEP
I used 5W30 full synthetic.
Jul 13, 2023 at 10:48 AM
  • 55,548 POSTS
Okay, then it is back to the valve adjustment procedure, when the valve cover is off, please check out the lobe wear on the camshafts as well. You can upload an image if you have any questions about wear.
Jul 14, 2023 at 2:00 AM
